Had a play with the 52cc chinese combi engine.
I measured the gap at 0.35mm, enlarging to 0.5mm has not made a difference so I will try again to 0.8mm. I am thinking the flywheel timing, or coil mount holes will need to be modified.
Someone mentioned variable advance coils, that retard below idle speed. Are there any that may fit this?
Yes, as close as possible would be best for a good spark, but it was suggested that a bigger gap could retard the timing.
I'm thinking a gap change wont be enough, I'll either have to adjust the coil mounting or the flywheel key. If I slot the coil mount holes that will give a couple milimetrrs adjustment.
Don't think it works like that, larger the gap would just create a weaker spark or if electronic probably not at all.
For something that's spinning at what 3000+ rpm retarding the timing will probably make absolutely zero differences probably.
Plus being a two stroke it's probably even more useless as the microsecond timing is so infinitely small it's probably barely even noticeable or measurable.
Having thought about it, my engine auger has the same issue of being a pain to start, hard pull or it hurts. Starting this combi is a real pain without the driveshaft fitted as theres not much to hold onto.
I got myself a timing light. Red marks are TDC, ignore the first blue mark (strobe was set +10). With the light set at zero, the clockwise most blue mark is roughly 24 degrees.
And just to help me avoid such stupidity in future I shall share my mistake. Do not start a clutched engine without the clutch bell/housing. I was lucky. A new spring is needed..
So is 24 degrees too much? Are there any variable coils I could fit for this engine?
The ignition is consistant across the rev range with no change at higher rpm, although it did seem to vary a little between multiple starts. I'll confirm that tomorrow.
Thanks.
Edited by kram
Could there be any other causes of this problem? Its a pain to turn over even with the ignition off, so perhaps I have gone down the wrong rabbit hole.
Add a decompression button?
A bit more testing and the recoil has broken, only retracts if you help it, but the spring is still very strong. Spring could be far too strong?
I made up a bracket to delay the ignition about 6 or 7 degrees. Not had a proper test but it starts - then the recoil went..
Edited by kram
