Even then the silky has a heavy rubber handle
Sent using Arbtalk Mobile App
Not if you just use the replacement blades without bolting them on....:001_tt2:
  • Replies 150
I've modded my 201t, and 660 and widened the exit on 346xp
It's just a cheap easy little tweak, but don't go mad or you may be needing a new piston 👍
My 201t sounds more like a 200t now
Josh Noon Tree Services
Did it make much difference to the 346xp josh?
Yes slightly, I haven't drilled the exhaust just lifted the flap up and opened up the exit hole
I suppose it'll pull a 18 inch bar better now?
I've done my 200t now exactly the same as Rich. It's brilliant!! I run a 14inch bar with full chisel chain and it pulls like a beast! The engine actually feels like it's breathing the way it should, it starts better and is far more responsive!
The case is plastic but there's that big metal piston and cylinder. That weighs a fair bit so take that out. Put a plastic cranking handle on the side of the sprocket so you can still cut with it
:lol: thank god for arbtalk :lol:
