Hey guys. Now I've got my pto saw sorted and paid for I'm looking towards a hydraulic log splitter. I'm a bit confused by the various ton ratings though. I have a small compact tractor which I think should run a ten ton ram, but is that big enough? I usually get by with a maul but I also get rounds that are a challenge and sometimes need wedges. Would a ten ton split that sort of thing or do I need bigger? I'm worried about ram speed with the flow rate of my little machine.:confused1:
Any pump will run any ram, some quicker some slower.
The force exerted by the ram (on the outward stroke) will be a function of the internal diameter and the pressure of the oil.
The speed will be a function of the internal diameter and the flow
If the internal pump on the compact isn't man enough for the job consider a PTO mounted pump.
Just bought a 18 ton PTO driven splitter for our compact. No problems running it and it splits anything we have with ease. I suspect the 13 ton model would have bee enough to split most stuff.
It won't have trouble if its a pto as it has its own pump, a hydraulic one runs off the tractors pump.
For a compact I would get a pto splitter.
The last lot I did was larch, around 2' diameter and 15" long. I struggled with the axe, most pieces needing two or three hits to get a piece off of them even working with the rings in the wood and not going straight through the middle. I guess it's all the little knots from all the branches around it?
The make I'm looking at do a 10, 14 and 18 ton. The other thing to consider is that I still really want to buy an old Unimog, so in the future I will have more than enough flow rate to run all but the biggest kit. If I use a PTO pump, I assume all I'll need is the pump itself and some kind of oil tank? Can you buy that as a complete kit or would I need to put it together myself?
You can but the parts individually the pump can be the size of your choice, it fits on a gearbox that either hangs on your PTO output, or driven by a PTO shaft
Check out flowfit on ebay for parts
Is it quick? Does it run off the pto?
Yes very and yes. To be fair it is the only hydraulic one I have ever used but the specifications suggest it if faster than most.
