You could pick up a new lucas barrel for £5 from the delightful ebay, or we just used a screwdriver in the 5000 we had. Not the answer you asked for but just my opinon. :-)
some what earlier than a 5000 . its a fordson major ( possible power major )that looks like its been converted to fourwheel drive by "roadless" ,But it isn't its just got 4wd wheels on the front axle google fordson parts or ebay ! the're like mf135 , old landy's etc plenty of grey parts .
Edited by bythamboy
Fordson Power major or Super major, they were the models pre 4000,5000 etc. made from 56 to about 64 time. good old girls, The key is usually the standard Lucas key with a single small notch cut in either side. Same key as fits most older Massey fergussons ( 135/165 etc), I also use a JD 4400 teleporter that has what looks like the same key. If a new key like that does not work then stick a new barrel onto it.
A
Edited by Alycidon
I got a new Lucas key but it goes in a few mm and then is too big (no jokes please). Someone said to file it down or is it possible a new barrel has been fitted which isn't a Lucas?
The Fordson lucas key ( and early Counties) was thinner then the MF ones otherwise looked the same.
