Rob,
(And this may be of use to others)
Is this chain you sell "Stihl narrow kerf .375 lo pro .043 39 drive links"
Product code: 3610 003 0039 suitable for the MS150T? And i assume it'll take the 3.2mm (1/8") files are what i'd use with this saw?
Posted it here for reference for others.
Cheers,
Chris
Cheers Chris - no in fact I need to do a chain for Martin (Burrell) as the chain the MS150 takes is a 1/4" pitch .043 chain. (And I'd sent a 1/4" .050 chain).
Rather clever of Stihl as they then have the only chain that will run on the saw (and also the bar is theirs as well).
I have just got a reel of it in so will list it shortly (and will post here).
:biggrin:
  • 3 weeks later...
Any news Rob? Want a few more bits off you too and will lump them in one order.
Cheers
Edit - is this in fact it - under the MS192C-E?
Lightweight chain for smallest chainsaws and pole saws. Cuts a very narrow kerf and makes the most of smaller chainsaws low power. Use with a .043 guage bar.
Edited by TerryTibbs
Done my research!
Cheers
That is a 3/8" pitch chain: 0.375 = 3/8.
You need a 1/4" pitch chain (0.250) for the MS 150T
:biggrin:
But you won't be able to post it out will you..?
oK all i'm going to say is its the only thing that lets down an other wise fantastic little saw down, IN A BIG WAY , my fingers are not slim, and my eye sight is poor , short sighted, (blind). the only way that I could run that saw would be to throw the chain away at point of needing sharpening. Every time I tried to file it snapped and scratched me pointing finger, sometimes making it bleed :001_huh:
I have had no problems sharpening mine, the chains don't last as long as a heavier chain, but a couple of brushes with the file & guide & the jobs a goodun.
Any chance a MS200 bar and sprocket could be fitted?:confused1:
I know it would take more of a pull than the 1/4" chain, but would make life much more simple.
The small chain suite it well . Great Little saw .
That's my opinion too, anything heavier would restrict the saw imo, the saw relies on a very narrow kerf, which in turn does give nice finish cuts.
I keep a cheepo pair of glasses in my sharpening box, as at my age I'm long sighted, that & the file guide results in a nice sharp saw.:001_smile:
