Rescued this old Victorian bedroom fireplace from a skip and thought it would make a great garden feature/heater.
Tried it today and I definitely need to create some draw:001_rolleyes:
What do you think I need in regards to flue pipe? I was thinking of it coming out the top to say 2m. Do these come up much as used/scrap?
Cheers,
Si
Edited by wisewood
You will need at least 4.5m I think. It might work on less but usually thats what you need for a stove, an open fire putting more heat into a chimney might work a bit shorter.
A
A
Cheers Al,
I think the neighbours might have issues with a 4.5 m flue in the garden:laugh1:
Just out of interest does the pipe diameter make much difference in pull, ie would a shorter flue work best if 6 or 7 " diam or 4 or 5"?
I think 2m will be fine , you see all these outdoor chimaners (sp) which are short and they work fine.
Sent from my HTC One X using Tapatalk 2
Hi Ian, good point mate, at the very least it will improve what 's there
ATM.
Like your style! :thumbup:
Ditto mate, looks well toasty:biggrin:
