  • Replies 21
Field maple burns well , so does Japanese maple . Burnt the both . Split and season and keep it aired but dry . Don't know what it weighs . If your down on the bump stops of the rear axle you got a bit too much in !
Both require splitting now to get the mositure out. Oak generally wants 2 years to season, when you burn the Oak you will find in a multifuel stove that it helps to put a bit of primary air under the grate as well as full secondary air.
Weight wise probably a tonne and a half- 2 tonnes. I think I would just about get it all on one IFW 8 x 5 trailer load.
A
Do you find that makes much difference? Common wisdom is that most water is lost through the end grain (although clearly some is lost through the long grain otherwise end-sealed timber would never dry). I like to stack firewood "round" as the splitting gives a quick visual estimate of how it's drying.
Tony S
This is what I do cos I got no choice . All my wood is stacked in lengths ( bark side up , like a stack of cord ) in the open . It gets rained on . I split what I can and fill my log stores . Split wood will dry / season quicker than un processed wood but only if you can keep it dry and aired . What I cant store in this way I leave as log lengths to minimize water up take . It works for me but it could be more efficient if I had more storage . does this make sense ?
i burnt some this winter, burnt ok, as for the weight chuck it all on and if its too much take a pic and put it on the overloaded thread lol.
Sagely words for the young padawan there Lyn.
