I've a burr oak butt which I'll be getting milled soon and have been wondering how much the through and through cut planks are likely to 'cup' as they dry. The largest planks will be about 6 feet long by 3 feet wide and it looks as though it will be solid burr over virtually the whole area. Does solid burr like this tend to cup less than plain oak? I wondered if the twisted grain might tend to resist the cupping? I've laid some concrete foundations and constructed a frame so that the sticks will be less than a foot apart and am proposing to mill it into mainly 50mm and 35mm planks plus some thicker pieces.
It is for my own future use and current thoughts are to use the planks for at least one dining table, a desk, large cupboard, in other words, items where large areas of solid burr should look good. If it does cup appeciably, I'll cut the planks into narrower pieces and use book matched pairs, but it would be good if single through and through planks would work.
Andrew
Hi Jonathan
I realised it's getting a bit late/risk of warm weather, but there has been a bit of a delay getting it milled. It will be done on a large static Stenner mill able to cut the full width planks to minimise the kerf/sawdust. I'll be stacking it on the north side of our house with ply covering the top and ends, so hopefully it will be fine. I'll post some pictures in due course.
Andrew
Andrew
I have no experience of drying solid oak burr but like Jonathan would love to see some pictures. Bet you can't wait to see inside the log...Are you planning a dining table with a solid burr top?
I think your plan sounds like a good one.
I milled one I'd had in the yard (for 2 years :blushing:) the other day - some nice timber but also a lot of shake...
Hi Andrew,
This isn't by any chance the butt I sold you?
Looking forward to seeing some pics and hope it yields some lovely timber!
Tim
With burr you will get the best planks off the outside, I would skim it all round to see the best bits then take planks accordingly once you have taken planks off all sides you can turn the rest I to any joinery you may need for legs etc.
Personal exp only qtr sawn stay flat ish all planks will warp bit with burr you have got to accept as you said you can then cut down and plain once dry to regain some beautifull burrs
http://Www.Copfordsawmill.co.uk
Follow us on Facebook too
Thanks for all the comments and yes Tim, it is the butt I bought from you.
I know the general advice with 'burry' timber is to cut planks off the outside and rotate it after each cut, but I'm hoping this one will be almost solid burr to the centre over at least half the circumference, so I'll take a chance and cut it through and through on this half of the butt. My priority is to get really wide planks, at least one of which will hopefully be a solid burr oak dining table top. The other half has a bit less burr, so I'll rotate it 90 degrees to get some 50mm quarter sawn planks and some thicker pieces on the outside.
Andrew
With hindsight, I probably need to keep an open mind about how it is milled and if the burr is disappearing as it is cut from the most burry side, I can decide on the best way forward. The following two pictures were taken by Tim who I bought the butt from. The first one shows the side with the most burr with a metre length ruler for scale. The second picture is one end where the burr appears to extend virtually to the heart. The left side is the most burry and appears to be clear of shakes or other defects. Not sure about the total quantity of timber. It was estimated to weigh a ton, but the loader who lifted into my trailer measured it as 1.4 tons. Maximum width over the burr is about 40 inches.
Andrew
