I went up the lane to buy 5 gallons of red diesel of my neighbour this afternoon. He had had a delivery a few days ago and then discovers the tank is empty again. So I went home and checked my heating oil tank. That was empty too. We both lost about 400 litres. They must have carried it off in 5 gallon cans as they could not have got a vehicle close.
My job for tomorrow evening is to start to make a metal cage to put round the tank.
John
Set up a tank with a gallon or two of diesel the rest whatever fluid you can think of , works better after a few beers guaranteed to make you feel better allround .
Be careful if you have a plastic tank, their favourite trick if they can't get into it is to get a red hot bit of pipe and push it through the bund into the tank! They take what they can then let the rest onto the ground which then cause all sorts of headaches to clear up and put right.
Bummer ! Really sorry rto hear . There are all kinds of things you can do as mentioned above , I have few my self but it don't get your oil back does it ? Bloody dids !
Neighbour at the farm had thier heating oil pinched thier tank is only 30 yards from my diesel tank which was empty at the time anyway, they only realsied when I went to ask if it was leaking as I had opened a manhole on the yard and stank of kero, they thought they had a problem with aga as had only just filled the tank, scum had undon the union at the tank drained it and done it back up, but must have spilt a load which had found its way into the drain :sneaky2:
