Timber values
tristan@arbcore.com
  • Replies 22
logger, i think log job back on will call m/day, ps the proper name is curley sycamore for those who dont know
Or even curly for that matter --didnt want to confuse things even more -- theyre not all as long in the tooth as me and thee fella. Cheers for letting us know on the other job.
if at all possible never summer fell a figured sycamore-- not always possible in arb work admittedly .
Good point!
If you HAVE too summer fell Sycamore you can leave the crown on the felled tree until the leaves wilt, this helps pull out the sap to reduce the staining.
Other methods are to get the butt planked immediately after felling and then stand the planks up on there end to let the sap run out.
Another is to drop the butt in a fast flowing river, Secured by a rope or chain, the flowing water will push/pull the sap out.
But as logger says far better to fell in the Autumn or winter, the rule I was told was once the black spots come on the leaf, where the aphid eggs were stuck to the back of the leaf, its safe to fell Sycamore for timber.
Good point!
Unless you can find a private user for the wood i think you would be struggling-- commercial buyers wont pay a premium on sycamore felled with the sap in regardless of what you try.The black fleck that discolours and devalues the timber can and usually does appear quite some time after the timber has been cut, and runs throughout the log. Far better to leave stood if possible,planking figured logs is a last resort.
You need stihl 088. it does pay off eventually. Always stand sycamore up on end as even if it doesnt go black, if it dries honey yellow it is not what a buyer of sycamore wants. It ought to be bone white when finished. Those black flecks are really sly, as stated by Logger. Found that out to vast cost not long after i started milling!!
Done the first one before thinning some big ash and syc - couldn't start until later than was ideal and ended up going through the knocking any of the decent sycamores over first them coming back to once everything else was down and dealt with a week or so later.
Didn't know about the other methods - always good to know :001_cool:
