Can anyone help identify this tirfor? I cannot find any markings on it, other than Tirfor and Super cast on one of the levers. It has approx 11/11.5mm cable.
Im after some shear pins if anyone could recommend a supplier too. It looks like the shear pins have long gone, should the handle just come off the end of the shaft? As its quite firmly stuck on there. Thanks
I've still got one TU15 IIRC 30cwt pull
Spare brass pins normally kept in that tubular carry handle with plastic bungs in either end to retain them. Chances are someone has driven som steel pins in instead
Thanks for all the replies, I was leaning towards it being the 1.5t one, should there be any markings on it anywhere lurking under the rust or would there originally have been a plate with them on attached to it?
