felling wedges
Yorkie
  • Replies 21
what is people's choice magnesium or plastic? any difference in make?
do you use a impact bar to drive them in or something else
cheers
yorkie
I like plastic as if you catch it with the saw chain damage is nil . Probably the same goes for mag but it seems a little harder . I whack em in with the back of the axe head or a big mallet . If its small stuff I use a felling lever not wedges .
Usually if the wedges are coming out it's for something fairly decent in size so usually I've got sledgehammer, a wooden shafted magnesium high lift and a pair of smaller plastic wedges.
That way the high lift does the work and the plastic ones just chase up the cut and the chances of clipping the highlift is minimal.
For hitting them, I've got a 7lb sledgehammer with a third of the shaft cut off so it's a lot less numb to swing.
Have toyed with the idea of an impact bar before but IMO I don't think it would have the weight for anything with much backlean and the length of the bar doesn't look like it would give much leverage compared to giving it a shove by hand.
