Not quite overloaded but a good load
Whats the pickup and whats it plated for if you don't mind me asking.
I'm thinking of getting a ford f150 4x4. From everything i've read the yank trucks are in a different relm when it comes to carrying and towing.
Hi, its a ford f250 super duty with 7.3 powerstroke diesel, 6 speed stick shift. Rated on V5 to tow 11ton on a gooseneck and can tow 3.5 ton on normal overun braked trailer and doesn't know its there. Class 7 mot and about to get a tacho fitted but trying to avoid an O licence if I can. I personaly wouldn't have a 150 (used to run a gmc 1500) the yanks only class them as a 1/2 ton pickup and if you want a work horse then you need a 250 or 2500 (dodge/chevy/gmc) but that's my opinion! Mate runs a dodge 1500 with the 5.7 hemi magnum multi displacement engine (runs on 4 cylinders basicaly when not under stress so improves mpg a lot), gas converted and engine etc is fantastic but running gear struggling abit with a lot of hard work and he's wishing he went for the 2500 now.
As above the 150s are toy trucks 250 upwards for real work, axles engines gearboxes suspension everything is twice the size on the bigger models
Sent using Arbtalk Mobile App
[ATTACH]119211[/ATTACH]
Last years grass silage
recognise this is it jims fb profile photo
