First attempt
Al.
Had a top day today, having a go at milling a fallen ash. Wife's eyes were glazing over, so I thought I'd share it with people that might appreciate it!!
Start of the day: The 395 with a 28" bar seemed huge, and an absolute monster when I was using it to cut the trunk, and the ripping chain flew through some knotty bits that wouldn't split, but mounted in the mill I was having some doubts...
Vicky, now a bit bored, having chased all the bunnies, settles down for a day's viewing. He did get chance to stretch his legs later when a fox came by; impressive sight watching him go full tilt over the neighbouring field, but all a bit optamistic!!
Bit nervous at this point....
And now a lot more relieved. Took about 5 minutes to go through, possibly less. I made the mistake of having the exhaust pointing up, so all the dust was coming straight in my face.
Set the saw to 2 inches, turned it over, and did the first "plank". Did consider doing it thicker, but the limiting factor is having to extract by hand, down a steep bank, over a dodgy footbridge over a stream, and up another bank. The middle planks I reckon are somewhere approaching 40-45kg each.
Had to take a bit off the side, as it was about 3 inch too wide for the mill. Used the 55 with a normal chain and did it by eye.
Hit the middle pretty much bang on, so I should have a nice pair of matched ends for the bookcase that this will be in a couple of years time; unless I change my mind.
All rounded off with a flock of longtailed tits; days don't get much better than this.:001_smile:
Anyway, that's it. Any suggestions about what I'm doing wrong greatfully received!!
Cheers, Al.
Pretty much perfect chainsaw milling if you ask me - good results and good method....
.... my only criticism would be the colour of your chainsaw mill - the colour green can deceive the eye and blend into the background causing irregular and crooked planks!
:001_smile:
Hi Rob, ha ha, yeah I did get it :001_smile:
I did have a look at the mills on your site, but the pockets weren't quite deep enough.:biggrin:
I was after something cheap and cheerful just to try it. Needless to say, I'm already looking at another mill for a larger bar. Unfortunately, I'm a pretty decent welder.:biggrin:
Cheers, Al.
