The Unicender is rated to break at 7000lbs. An eye2eye way over 22kn.
Those scaffold knots on the HH will cut through and break below 40kn. What was your point Ian? The HH body was built to last....and it will. Designed for treemen that dont have a gear addiction.
  • Replies 839
I heard through Mike Popham that you bent the zk-1 and deformed your zk-2 prototype. Maybe the 40kn was designed to test you!! Go on....see if you can !!
Nah, that was my zk1 Paul, I think it's from too many drop through redirects. Drop testing after the initial bend probably didn't help either:)
It was an example of something low, nothing more just trying to get my head round why somethings have low failure strength and others high. :001_smile: just not sure why they dont or if they do have a rec kn level what it is.
haha yeah, he was impressed with my zk2 and how id damaged it so badly through climbing. :thumbup:
Really rate the hitchhiker after another blast with it on Saturday, only a couple little niggles with it, the bina did get a little hot on a long decent but I guess that's normal??? And Not sure about the bina you get with it as the gate seems really easy to open, almost to the point it feels like a 2 way bina!!! is it advisable to add a different steel oval bina of some sort? Really rocking it though :)
Sent from my iPhone using Arbtalk Mobile App
The krab supplied with the HH is integral, as the body of the device is designed to fit & secondly it is steel, which is more abrasion resistant & dissapates the heat generated far better.
As for the gate, is the krab clean & functioning OK?
Yes mate it's all fine but it just felt so easy to open, I see what you mean though and had noticed the size difference of the bina compared to other steel ones, it's a lot chunkier :)
Yur, the steelie feels way to easy to spin open....???......probably just imagining it?? I don't think much on it now anyway.
We made a video for a Japanese supplier.....[ame=http://www.youtube.com/watch?v=l6F5A73EfQ0&sns=em]?????????? (Introduction of Hitch Hiker) - YouTube[/ame]
