How have they repaired that? Is it a complete roof off( and very costly) or can/has it been repaired cheaper?
Thanks,
H
H, re-supported and glued back together using a gap-filling epoxy resin with similar modulus of elasticity as the timber. The glued joint then stitch dowelled with ss rod embedded in a less viscous epoxy resin.
'Theoretically' that would restore the timber to its former state. However, because its former state was inadequate for the stresses ( because of the slope of grain issue) further failure would be possible as fibres part parallel to the glued joint as the load is reapplied to the truss. That is a design issue rather than a materials issue; so it was agreed to introduce a raking post at the joint node. this satisfied the headroom requirements whilst not reducing floor plan and it could be argued, added to the aesthetic because its a traditional timber framing technique. Apparently the roof finishes didnt require any action. The overturned brickwork and blockwork was rebuilt
Sorry for the delayed reply!
  • Replies 38
  • 3 months later...
two great looking projects there farmer john. like your dovetailed collar ties. pretty awesome king post trusses.
and thanks for the recommendation alec.
can we have a timber framing page somewhere?
rick
  • 1 month later...
Just been back to a clients place where I made some A frames so I took some pictures. And before you ask yes I know the uprights serve no structural purpose but the client wanted some extra detail.
Looks a fantastic project. :biggrin:
I'd like to cut my teeth doing some framing as I could then do the whole process from tree to building... may have a go at something small first as bought a book a while ago....
:001_smile:
