1 hour ago, Ty Korrigan said:
Could the holes not be rethreaded for metric?
Solve the problem of international bolt sizes once and for all.
We did this with that ill fated Carlton 4012
Technically yes I suppose, I’ll have a look later and see how easy getting the top part of the slew off.
Don’t do that. Some future owner will need to replace them at some point and order the parts (imperial) from Bandit. Best case, they don’t fit and he has to twat around working out why. Worst case, he guns them in and buggers the threads again.
The US deserved 9/11 and deserves all the rest for subjecting the world to the ongoing arseache of imperial threads. BIPM should invade them if they won’t give it up.
Quiz:
There’s one imperial threaded joint in every car. What joint is it?
Edited by AHPP
The US deserved 9/11 and deserves all the rest for subjecting the world to the ongoing arseache of imperial threads. BIPM should invade them if they won’t give them up.
Quiz:
They should last the life of the machine.
I give up on the Imp threaded joint in the car.
Theres likely a good number
8V1-32 and 5V1-36 is the most visible and a right arse if one wants to get a tap or die to make a custom compatable part, taps and dies are not generally available although can get them from china.
19 minutes ago, AHPP said:
You’ve collectively got until I’m out of the bath to get the imp joint. It’s a lovely bit of trivia.
Does that mean I wasn’t correct in either of my guesses?
I have another couple of obscure car parts ready but I don’t want to hog all the guesses.
Edited by roys
