Maybe worth considering through-drilling a couple (particularly if some have damaged threads now, which may be likely for the last few that let go) and replacing with longer bolts and visible nylocks that you’d at least be able to see?
True, also might be worth putting it back together, putting a bit of lipstick on it, and selling it on for what I paid for it, buying a digger and subbing out the grinding.
When you get the digger only slew clockwise, if you go counter clockwise the cab will fall off!
On 05/12/2025 at 20:55, openspaceman said:
I had assumed it would be easier to pull the whole shrub then cut and feed a chipper.  So cut and chip then go over the ground to pull roots is better?
It would be easier but it’s what equipment is available and how it works.  The shears are fixed in place with 3-4 big bolts and nuts.  So taking on and off is a pita.  Larger shears for larger machines are available with retractable shears on a button but Ive never 1 for the mini diggers.   Hopefully wrong!
18 hours ago, Mick Dempsey said:
They’re coming from the UK.
Could the holes not be rethreaded for metric?
Solve the problem of international bolt sizes once and for all.
We did this with that ill fated Carlton 4012
17 hours ago, Mick Dempsey said:
Not doable, they’re only accessible under the machine, after taking off a protective plate, not visible only ‘feelable’
Well, men of a certain age are advised to feel their nuts regularly...
Friday was a hedge day in Essé South of Rennes.
We rucked up to this council horror surrounding our work site.
Luckily no judgemental competitors drove past to add 2+2 and make 5
I lost count after 20 and there are still dozens more Liquid Amber street trees that are yet to receive the same treatment, breaks my heart that some councils haven't moved with the times.
It wouldn't cost the council very much to let an experienced arborist just do the cutting whilst they cleared up something I already do this for one commune already equipped with a chipper.
