  • Replies 29
a tipping dyna body is a good idea!!!!!
i have been using a cheap winch off ebay called winchmax there bright orange
they are apparently built in the same factory as the super winch
i had an x9 for a good few years so i feel i can compare both without being biast
the x9 was faultless as expected & did everything i asked of it i used to compete in team recovery compitions & used it for general tree & ground works so it was a work & play tool used most days of the week
i dont do any serious off roading any more & dont really need an expensive winch so thought for a change i would try a winch max there not that expensive & i only need one for the odd tree & winching the odd car out of a ditch or just plain pulling the truck through the woods when the going gets tough
iv had it on the lux for a good 18 months & has been used a good few times & has worked faultless it is not as good a spec (seloniods are not that heavy duty on it) as the x9 but it was less than half the price so i`m pleased with it!!
i have also seen bigger winchmax winchs mounted on several big plant trucks at the local machinery sales so they must be good if the big boys are using them!!!!
i also have the winch max quad winch on my polaris will give a review on that when it has been properly tested!!
Whats the payload on that Steve - looks good!
about half a tonne if you have a big driver. The gross train on a single cab is only 2500kg whereas king cab nearly 3 tonne. If I change the truck I will put the body on a king cab if I can
