Have to say think you must be off your nut going for a mogg for those prices , tractor all the way , going to be so much more flexible .
HI ALL why are there so many MOGS FOR SALE NOW ON THE NET :sneaky2:JON :thumbup:
  • Replies 45
everybody thats recomending a tractor seems to forget one thing....it takes a long time to get anywhere at 20mph....and thats all you are alowed to do in a tractor, I dont care if its got a 40k, or a 50k gearbox, plod WILL prosecute you for speeding, and if they want to push it, theres a dozen other offences related to construction and use they can get you on if you exceed 20mph, its not worth it, get the mog, and use it, itll still be worth the money when you come to sell it on, but youll have had the fun of owning and operating it
If you want to work local then tractor for arb works ok, but some days I can do 300km in the mog.... Running cost in the same range has a small truck 7.5/11 tons. (thats a fact!)
If you buy a clunker the you have no one to blame but yourself, same rule has a truck. Lots of people claiming the expense of running one, just the same has any larger vehicle.
Have them serviced properly, repaired correctly, carry out duty of care, do preventitive maintenance.
The reason for regs on operating licences connected with trucks is 'can you show that you can afford to operate that vehicle' (ie; money put aside, maintenance contract in place etc).
Treat you mog has the above.
If you go out as a haulage contractor and buy a 'clapped out' truck for your business it wouldn't be good practice. I read on here lots looking at bottom end mogs. mogs that have historical issues. Then we have a list of expensive repairs!
You generally get what you pay for. If you are not in a position to buy one, don't get it! doesn't matter if its a landrover/scania/or mog.
Thought it was 40mph with full mud guards ?
Sent from my GT-N7000 using Tapatalk 2
No.
Full air brakes and full suspension, same for trailer if towing.
Because the bottom has fallen out of the UK Tree industry or and VOSA are busting people running on Cherry?
how about ringing around your area and seeing if anyone would be intrested in your service/idea??
my limited experience with the older ones (1988) is that is always somthing going wrong with them be it major or minor.
they are very versetile tho, are they that good off road??
had our one stuck loads but that could be down to dodgy driving!
good luck with your project( wish i had 50k to invest!!!)
carl
