You could do a hell of a lot worse than speaking to Richard at Trojan 4x4 outside Carlisle (07703 581174).
Top bloke & if he can't do it then nobody can - and if you're not 100% happy with the job then I'll buy the result myself.
I've been to him with hundreds of mad projects over the years & he's never failed to supply a solution.
oh and the wheels are going to be re sprayed black before MOT also,should look bit tougher.
Future plans full mossy oak vinyl wrap some portal axles and alot bigger rubber,td5 or tdi conversion cant decide which yet and bright orange company writing
I wouldn't put portal axels on if your going off roading mate, they were prone to the chains snapping if one wheel lost grip and started spinning and then bit it can snap the chains.
