Any idea WTF this lot is!? Was suppose to be a full hydraulic superwinch H14W kit... Seems to me that its a PTO kit, with a hydraulic tank, some kind of hydraulic pump, the wrong hoses, and some kind of spool valve but probably the wrong one!
Winch input is a shaft...
Little red pump, is that a hydraulic pump? Looks a bit small but would fit on the transfer box with the silver adapter from the PTO kit
Sent from my iPad using Arbtalk mobile app
EDIT. First photo shows what i think is full kit on the left, and random hydraulic stuff on the right. Various mounting brackets etc with it not shown in the photo.
You have 2 set ups there the direct drive is set up properly and looks to be complete, the remainder is a hydraulic PTO set up minus the winch, I would be interested in the hydraulic parts if you want to sell.
That's great thanks.
Sorry but its the hydraulic stuff I wanted not the shaft PTO set up!!!
Charlie.
The pto set up is all there, just bolt onto back of transfer box, run your shafts to the winch, hardest part is routing the shafts.
I didn't really want a PTO set up... Was after hydraulic for various reasons.
Biggest problem is transfer box is a few inches further back than normal on my defender so to fit the big PTO box thing you would have to cut out a crossmember and weld in a new one somewhere.
Thanks,
Charlie.
Might know somebody who would be interested in the pto bits if you want to part with them.
Don't know what they're worth but most likely going back for a refund :(
Waz, yes it's brand new/unused old stock. Winch is stamped 2005 I think.
Thanks,
C
Evening all, after a less than great day and following a row with the mrs:rolleyes: I have been caught out by my reversing braille:banghead:.
So does anybody know where I can get a new lense (phot below hopefully) from? Not sure if it's a oem part or not, any leads that reduce my search would be cool.
Cheers
Mark
Sent from my GT-S5690 using Tapatalk 2
