wow.......just wow :001_tt1:
yeah, he made it himself. was a 110 now has rear bogie axle and roll-on roll-off body. still got stuck in the mud though!:001_tongue:
  • Replies 178
Can't be much worse than a boyfriend?
Except you'll probably spend more time underneath/on top of/or beside your landy,than a partner.
But then again,no one will press charges if you bash your landy.
:laugh1: Good point..
I have always steered well clear of getting either, they are probably just as bad as each other. One you'll spend all weekend lying underneath covered in gunk, and the other i can only imagine.......
I have always steered well clear of getting either, they are probably just as bad as each other. One you'll spend all weekend lying underneath covered in gunk, and then you'll have to go and fix your broken landy.......
:001_tongue:
Very impressive, but a 6x4 with a rear bogie will always get stuck as the non driven axle will stop th eother rear axle gripping.
I raced against a modified series 3. V12 F1 engine in the back. Two cooling fans directly above the engine, which was exposed. Very wide tyres. Has anyone seen anything like this. I'm off to the google.
Edited by Jason James Gairn
self importance retraction
