IT is different if you pass a trailer ttest this year you will have B+E next year if you pass the test it will be BE at present there is no weight limit on trailers so we can tow 4000kg trailer for example a defender rigged for air brakes. If you pass BE next year there will be a weigt limit of 3500kg on the rtrailer regardless.
  • Replies 20
you nailed it the change is to new B+E drivers that want a trailer over 3500kg, there is no change to BE so rob you did it just in time, the new rules are MORE restrictive, swines!
That's how I read it, us oldies will no longer be able to tow trailers over 3.5 tonne, not that I ever have bar perhaps a bit of overloading.
I guess it's aimed at the under 7.5 tonne articulated units mostly.
Or have we misread the specifics?
It,s not retrospective.
The new rules will apply if you pass your test after that date
Lol yeah it pulled him over about a foot
Lost a full tank of red
Bent the back wind down leg and wheel arch
Lucky the digger driver was good!
Sent from my GT-S5830i using Tapatalk 2
  • 3 weeks later...
The new rules on towing with B category vehicles will make virtually no difference to anyone because all trailers over 3500 kgs plated MAM come under different rules in regards to their braking systems - such as needing air brakes
Those getting B+E after Jan 2013 will effectively be limited to a max total MAM weight of 7000 kgs or 7.0 tonnes
3.5 tonnes for the vehicle and 3.5 tonnes for the trailer
I'll bet no-one on here tows a trailer over 3500 kgs with a vehicle under 3500
