I started a thread a while ago as my truck has been struggling to tip off chip.
If you can get it started (2 blokes lifting whilst trying to tip) it's fine but apart from that it struggles now even with it not even being half full.
Topped up the resevoir, there's no leaks.
Spoke to someone at del Engineering and its going to cost £500 to get a new motor.
Does anyone know of someone Nr Guildford that might be able to service the motor or help in any way?
Cheers
Jonny
Is there a manufacturers name on the powerpack?
A new motor shouldn't cost anything like £500, even a complete new powerpack should only be £250-300.
Don't bother , same happend to mine I took it off and my local hydo place stripped it then told me we can't get parts for it , they re assembled it an I re fitted it whilst I weighed up my options and low and be hold it tipped better than Eva before , my point being get the moto serviced
ingemex body? with a scissor mechanism for the ram? it'll lift a 'legal' load. i carry a jack for a boost on the days we're over(most then). good trucks let down by the pony hydraulics....
depending the make ,look on the bit between the motor & tank, thers an alloy cap nut under ther is a screw that you turn ,press the tipper swirch & turn the screw either way till it lifts, they can only tip what they carry ,i did it on my daily :biggrin:
  • 1 month later...
Well after a few weeks of shovelling I bit the bullet and bought a new power pack from Del through a local company. Total cost £510(pack, delivery and fluid) just glad it's working ok again!! Now If only stihl would fix my 660.....
Does the motor sound if it's struggling??? Does it get hot or smoke?? I found it's the motor 99% of the time not the hydraulics. If it is doing the above it's most likley the brushes in the motor have gone. Don't bother with getting it reconned just buy a new motor and pump unit complete with res. the units on ifor williams trailers are very good/powerfull have no problem with 2.5t of topsoil!!
