a good friend dropped a very big piece of oak into a rigging line and snapped the rope. we roughly calculated the load at the anchor (using a forces calculator) to be 56t. the big impact block and 22mm dead eye took it but the rope snapped over the block. wonder what would of happened with the dyneema sling?
  • Replies 471
It should be standard practice to let all rigged pieces run as far as possible with gradual and gentle breaking. I expect my groundies to stop the piece just before it hits the ground where possible.
I do not like nasty shaking in the tree, and it reduces the excess loading on my equipment.
Sent from my Galaxy arse using tupping talk.
Check ALL the simple things first.
Scary thing when the line snaps, had the rigging block flip up infront if me almost hitting me in the face then i watched this log roll down the customers front garden.
Sent from my GT-I9300T using Tapatalk 2
is that a x10 calc? maybe the rope was flawed in someway.
The dyneema is rated at 12.5T minus the whoopie set at 40%, so at best you'd want 8 slings to hold that up:001_rolleyes:
For each meter that a log is allowed to free fall multiply its original weight by 3+1.
E.g 1m free fall with 4ft x12 inch diameter beech. Shock load of- 80kg x3 = 240kg + 80kg shock load 320kg
2m free fall of 4ft x12 inch diameter beech. 80kg x 6 = 480kg +80kg= 550kg
It was something like a 1000kg piece with 12m of rope in the system and the tie point being 30cm above the block. Like i said, I'll try find the link
How big a piece were you taking?
