Husky' 435?
New Forest DEAN
  • Replies 28
The max' size would be 18 inches, but I suspect the bulk of the logs would be 12 inches in diameter. From what I understand, trees are thicker at the bottom and thinner at the top......
As far as chain sharpening, imagine you are talking to an idiot...:biggrin:
Anyone want to sell a 346?
Cheers - DEAN.
Three years ago I was in the same position, I had been using a very old Stihl 009 but wanted something with more go.
I am guessing £290 is the top end of your budget and you can buy a wealth of saws from secondhand pro saws to lower power, home owner saws brand new.
My opinion in this case is always look for a tidy secondhand 345/350 Husqvarna. The 346, 560XP that the lads on here are talking about are pro saws and will probably scare the bejesus out of you.
The two saws I am recommending will be great on a 15" bar and cut your 12" - 18" with no issues, both will be a joy to use and cut your firewood for years to come - I had a 345 for three years and cut loads of firewood - always a joy to use!
I had a 435 for a year or so and it was a great little saw running a 15" bar it never felt under powered to me it coped with logging some 16-18" ish poplar no problem. I have recomeneded this saw to a couple of friends who are also more than happy with them. I only got rid of mine as I traded it in against my current saw (353) as I was getting more work and needed a bit more power and the reliability of a pro spec saw still only running 15" bar but I would think for your needs it would be overkill and a waste of money unless you plan to do more in the future.
Cheers - DEAN.
Ok. I don't think you are an idiot, far from it ! but get someone who knows what they are talking about to teach you how to sharpen up . A cheap B+Q saw that is razor sharp is worth more to you at that moment in time than the best pro saw if the pro saw is blunt .
Cheers - DEAN.
Oh yea , in a minuet someone is going to mention PPE and college oh I just did ! :biggrin:
