  • Replies 26
as the title says is anybody else having starting probs with these new saws as ours is very difficult to start when hot :thumbdown:
I had a similar problem with my 560 . It was cured by fitting the next up hotter plug . This was done on Husqvarna technicals recomendation . Worth a try ?
havn't yet found out where half throttle is :confused1: some times it does sometimes it doesn't, nothing positive to tell ya where it is, anyone enlighten me?
Turn the choke on then off...its then on half throttle....i believe, dont actually have the saw
Have u read the manual of how to start it hot? Takes some getting used to
As above.
Mine was a pig to start after refuelling (but still warm) til I read the manual. I kept flooding it by trying to get it to fire on full choke and not using the primer either (like you could with a normal saw)
Normal warm starts don't seem to be a problem though, most of the time it'll go without half revs though if it's just been off for a few min.
EDIT: was a bit slow with my reply.
Is it all hot starts that it's a pig on?
