Hobbs or GRCS or other
Lee Winger
  • Replies 93
The hobbs can take wood better, though the GRCS is a better cranker.
And a porty is better than trunck wraps.
I tottally disagree. Sorry Bodean. I dont think you have thought this through. I dont for one minute think you have properly explored the full uses of the fixed bollard or the ratcheting capstan. You are mainly a climber, and your ground crew is often not as qualified as you. So you are not the one primarly using these devices.
When I dropped a volvo station wagon from a tree and shock loaded the new Hobbs and also the GRCS, the GRCS had minor damage to the tune of $160.00 dollars using the winch capstan not the fixed bollard which is the 'weaker' component of the GRCS. The Hobbs bent the main arbor which distroyed the entire unit. The only way to fix the hobbs would be to cut it apart with a plasma torch and re-manufactur it.
The 'Volvo Drop Test' video is available for all to buy from:
http://www.atreestory.com/videos5.php
There is alot of misinformation regarding not only which unit is 'better' but also how to properly use these devices.
Both devices require training to use properly.
Yes, you can figure out how to use them, but maximum loads, proper wrap configuration, etc. etc. are essential for proper use.
I am not a grcs salesman, nor do I get any compensation for talking up one unit over the other.
I learned on the Hobbs back in the 1980s and when the GRCS came out, I bought my first one. My thinking was, I wanted to truly test both units to distruction and decide for myself which unit is 'stronger'.
I dont in anyway represent either maker of these units, and my opinions are my own.
Hobbs= boat anchor
GRCS= evolutionary leap in technology
:hello:
