Flatbed trailer repair
Dean Lofthouse
This is how i spent my weekend
This is the trailer I used to transport my Mewp. The mewp weighs 2.9t and because there is so much overhang behind the rear axle, the leverage normally lifts the land rover back end right off the floor when tracking the mewp on using the ramps. It even lifted the Landcruiser Amazons back end up.
When I used it the other day I tracked it on but the trailer was not level, resulting in most of the weight being on just one of the two big girders that run the length of the trailer. The girder gave way and bent down. I thought the trailer may be a right off and was going to buy a new one. So instead, I got my angle grinder out and set to, taking the opportunity whilst repairing the trailer to shorten it and reduce the leverage effect.
I cut the chassis rail to relieve the stresses and straighten it up then filled in the gap with weld and added a 10mm plate for strength
More images to follow, tapatalk says no
  • Replies 25
