Transporting Small Tractor from Northen Ireland
Ty Unnos
Hi guys
I need to get a compact tractor moved from Northern Ireland to North Wales.
I have placed adverts on shiply and uship but not found the right offer yet.
It is only small - under 3.5m and 1200kg.
Access is trick at the delivery end so would suit a single car transporter.
Could also drop off at a local tractor dealer with ramps if that helped.
Does anyone know of a haulier that comes over on the ferry?
Or an outfit that does car delivery or similar?
Cheers
Simply leave your compact tractor unattended anywhere in rural England. Pop back the next day and Bobs your uncle, some enterprising traveller will have got it to Wales and on a ferry to Ireland before you've even had your brekkie. Job done.
A friend of mine that imports UK cars uses NVD ( National Vehicle Deliveries) here in Ireland.Thay do door to door or can put it on the ferry for you to collect on the other side.The'yre well known over here and have a good reputation.Hope this helps.
Thanks - I will try the suggested companies. I have considered driving it. Its not road registered and top speed is 21mph so unlikely to out run the long arm of the law! The other option is of course to drive over with a trailer and get it. Its not so far but the ferry is not cheap and Liverpool - Belfast is eight hours each way!
Go belfast / stranraer. Takes about 2.5 hours over water.....then only a weeks ride down to north wales:)
http://www.kinnoirwoodfuel.co.uk
