Thanks Paul - due to the undulating ground a robo flail won’t work otherwise ours would be on it! Just trying to belt and brace it as its highways works probably over thinking it. Cheers
Edited by JLA1990
We will be accessing using ropes regardless of height, surely this must fall into one or the other?  We have nptc but not irata hence the question. We can have a concise/well formulated set of RAMS but doesn’t account for not having the base tickets.
The nptc cs38 is "access a tree using rope and harness" so not really relevant.
 From the irata website "IRATA International’s rope access system is a safe method of working at height where ropes and associated equipment are used to gain access to and from the work position, and to be supported there"
Is there a risk of falling from height and being injured? If not, it isn't work at height, you are just using ropes for stability. Holding nptc tickets would give you assurance the people are competent to wear a harness, maybe helpful.
It seems a bit of a rabbit hole to me, scrambling about on top of a conifer hedge isnt covered by nptc either but we all do it.
In terms of a 'base ticket', interpreted as "evidence of adequate training", if its a prerequisite / justified it may be worth considering something like this
ELEMENTSAFETY.CO.UK
This course will train you to manage and maintain your own and co-worker safety while working on slopes. Find out more here
Thanks Dan & Paul for your comments. Thanks for the link Paul, food for thought. I wonder whether in-house training would suffice to show adequate training (from what I can see from the link it’s a day course and shows no accrediting body). It’s certainly not a prerequisite for this site more something that will make our works easier, as suggested I’m probably overthinking and maybe going down a rabbit hole. Cheers
