If you use Aspen2 you may find that your engine will idle slower.
Adjust the (LA) screw in to get engine to idle at factory speed.
You may also want to adjust the lower range mixture screw to give more fuel if the engine is not as snappy as running pump fuel.
(L) screw unscrew 1/8 of a turn.
You may not need to do any of the above and if you did you would need to reset if you returned to pump fuels.
This only takes 30sec to do!
Please call me 07568 108953 or email [email protected] if you need and help or just for a chat.
Kind regards
Eddie
Thanks for the info.
:thumbup:
It's something I will be looking in too.
New Dealer.
Ben Burgess Beeston.
Dereham Road
Beeston
Kings Lynn
PE32 2LE
Tel 01328 701347
Phone to check stock.
They are starting off small but please let them know you will buy from them if you pop into the shop.
One question eddy, do you do aspen stickers for putting on a combi can ?
Hi,
The dealer should have machine stickers that are the size of a large stamp and stick really well to plastic. Red for 2-stroke and Blue for 4-stroke.
Like this, most of my saws are now run on it so they are marked as a few of the older saws are still on pump fuel, helps the lads remember and if I'm working with someone new it is a warning to them.
Just purchased some to give it a go.
2x 5l @ £15(+VAT)= £18 each.
Is that correct?
(made this Yorkshiremans knees buckle :001_huh: )
Sounds about right bud. Different dealers will have different prices from £17.50 to £21 a can
Hi,
I have herd of some dealers charging £25 for 5l of Aspen2!!!!!!
As Barrie as said the margin on Aspen is small so a discount can only work if your buying a pallet of fuel and having it delivered so the dealer has no handling.
If you did buy a pallet you would get a discount and free delivery.
Kind regards
Eddie
Eddie I spoke to you yesterday on the phone, apart from killing my phone, it was good to talk too you and there's a PM making it's way to you in a minute with what we talked about.
Having just purchased a Husqvarna 365 and having a summer use only Stihl trimmer, I though it better to use Aspen 2 than the normal mix.
Having no local dealer, I found an online dealer who delivered and had free delivery for items over £50. I've ordered three 5ltr os Aspen 2 for £56.95 delivered which turned out rather handy.
I've no idea if the courier knows what they're delivering so I'm a little hesetent in naming the company, but if they do it's a rather simple way for us with no dealers about to get our hands on some Aspen.
