Have you asked them before now? Hope you gave them Eddie's contact details.
Many times sent a few emails last year about it and I gave Eddie there details but they must not be interested :thumbdown:
A pal of mine was round the other day so I could sort some of his saws out and he's been a tree surgeon for many years, he's never heard of it either.. We must be in the dark ages around these parts.
If the golf course where I'm a member and my dad works used it they would have next to none knackered machines, probably why they don't sell aspen because they would lose out on sales of new equipment?
Strimmers hedge trimmers and blowers sit all winter with the fuel that was left in them and the feul that was mixed during the summer for them is what goes in them! 6 month old feul will be fine in them:thumbup1:
Hi. Some dealers want all your kit to breakdown!
Dealers that sell and use Aspen have seen the workshop get more work because of the higher number of customers coming into their shop and people coming in more often. Aspen has also gets dealers new customers.
We work hard to fill in gaps on our map and as you can see we add new shops every month. I can't make dealers have it but attitudes are changing and more dealers are contacting us who had said it was not for them but now they want to look again. We have lots of dealers who are close to stocking Aspen but they are slow to commit to placing an order.
Please keep asking for Aspen and letting me have details of dealers who you would like to stock it.
Thanks for all your support!
Eddie
  • 3 weeks later...
New Dealer!
Simpson Marine
West Quay
Newhaven
East Sussex
BN9 9BT
01273 612612
Not sure if they will stock Aspen2 but if you ask they can add it to their next order.
Hi all,
Just got back from a week in Northern Ireland.
Worked at the Balmoral Show and called on a few possible new Aspen dealers.
If you're out in NI please then check our dealer map over the next few weeks as you should see some new dealers and better coverage of the area.
Where ever you are and you would like to get hold of Aspen please keep checking the map as we are adding dealers all the time all around the UK
Picked up our new strimmer yesterday. I presume the dealer put that sticker on as a sort of joke since I'd been grumbling about his price for Aspen. I was surprised to here that he uses the Stihl equivalent in his workshop, and the machine was handed over with 1/2 tank of Stihl. He says he uses Stihl as it costs less than Aspen (I thought it was the other way round).
  • 1 month later...
I ran out of aspen on saturday so put 3 tanks on petrol mix through the 372xp, on the 4th tank, the saw would not pick up revs. Then would not run at all.
Got home and put aspen back in 3 pulls problem solved.
Whats the price of apsen at the moment has it changed?
Great to hear another positive for Aspen!
The price of Aspen has not changed in over 2 years and remains at £18.98 inc vat for 5litres of Aspen2, although the oil content has been upgraded to FRT.
(£18.49 for the 4 stroke version)
hope this helps
I think aspen is definitely worth using for low use or in a hedgetrimmer where the fumes are in your face, but when you praise it be fair guys. I have found problems when switching from pump fuel to aspen which I put down to carb tuning. I think it was just 1/8 or 1/4 of turn of a mixture screw when I changed from one to the other. Can't remember which way now but some of my machines seemed unaffected while one would hardly run. Might be of use to know if carbs are generally adjusted richer or weaker ?
It is important to note that there are also tuning issues when switching between different makes of petrol, or switching between old petrol and fresh petrol.
Switching between summer grade and winter grade petrol also causes engines to run slightly differently, requiring tuning for optimum performance.
I get loads of 2 strokes in that run on petrol, but do not run quite right. A little tweak on the mixture screws will often sort them out.
But Aspen is no exception, it is after all, slightly different in density and vapour pressure to fresh pump petrol, so it is inevitable that some carbs will need a tweak.
Having said that, I have changed thousands over to Aspen and many have required no retuning at all, but some have required a slight adjustment.
This adjustment, if needed, is only needed on the L screw ( idle jet) and always needs to be a little richer, just to ensure a smooth idle and pick up. The adjustment will usually be no more than 1/8 turn and very, very occasionally, a 1/4 turn may be needed.
This is because Aspen is a little less volatile and as such can be slightly more difficult on cold start and tick over on some engines with 'colder' fuel lines.
The H screw needs no adjustment, as the difference in volatility is not noticed through the main jet.
Usually, an engine tuned to run on Aspen will have no problem coping with the slightly richer mixture when run on petrol.
Hope this helps.
Barrie
