what sort of strop you using? ive got one with approx a 2" ring around 3 inch from the saw that clips onto the tool caribina which the strop fixes onto the harness
use a screw gate tool bina with the screw always open
  • Replies 23
Just a basic length of rope with a krab on each end.
I'm just after a hook that will fix to my harness basically :001_smile:
I use a caritool, and have only had to replace it once in two years.
Downside to using one: I once had the saw strop, my rope, my strop and a branch all in it at the same time, I couldn't move!
I started using a saw hook earlier this year and I love it. Its a regular carabiner with the whole gate surgically removed and permanently attached to the harness just behind / past the right D ring.
For security, the saw is attached to the regular tool ring on my harness with a standard bungee strop, but put on the opposite way round to normal. Ideally, cut that bungee ring off too. The carabiner attached to the saw drops into the hook one handed and without ever letting go of the saw handle. You don`t even have to look at it to `gun-sling` the saw back into action. It works on bigger saws too. No more dangling saws below your feet. If a lowering rope brushed past the climber, it could well catch the hook so I`m not recommending it. ( But it is sooo much easier to use.)
I use one of these
http://tinyurl.com/6nq2x2
It has a back plate on it and doesn’t wander about I couldn’t thread it onto the belt so I replaced the rivet at the top with an “allen” screw. It can now be dismantled to get it onto the belt. It’s on it’s third harness.
Andy
Edited by treequip
changed to tiny url
