346 xp chain
brewpup
got old chain box it has measurements on that say .325 .050"/1.3mm. which is slightly diff to what timbercutter says .but would that size be ok.only 0.2mm out but me being a builder same village is normally ok.
Was that the chain that came with the saw? Just asking because .050"/1.3mm is not the usual size on the 346 here or in the USA, so check the numbers on the bar to make sure it is a .0502/1.3mm bar too.
If its 1.3 (narrow kef) The husqvarna "pixal" chain will fit . If its 1.5 wide bar groove I have heard it said you can use either but not the other way round as a 1,5 will bind in a 1,3 wide bar groove .
I think if you use a 1.3 narrow kerf chain in a 1.5 std bar you are likely to get binding in the cut as the kerf will be hardly any wider than the bar.
It will go round ok out of the wood though.
