  • Replies 46
I never realised how much time I used (wasted) before I got one.
Being able to stand directly below the target branch is a great advantage because the descending line is just as 'neat' as the ascending section.
I was once used a Big Shot to set an access line in a 130ft Redwood, I fired the bag and it went clear over the top and disappeared into the sky, about two minutes later the line seemed suspended from the sky, i pulled on the line only to discover the bag had lodged itself in a crater on the Moon, ended up pulling the Moon back down to Earth.......wrecked the guy's greenhouse so it did.
:001_smile: So .... is that a thumbs-up or a thumbs-down? :biggrin:
With a small bit of practice Big Shots are fantastic. You dont need all the power that they can produce but its there if needed. Defo on the must have list with a harness, climbing line, cube, ect :thumbup:
2 questions Tim,
1 where did you get a 240,000 mile long throw line, and 2 why were you climbing a redwood at night?
In his defense - he might have tied two together. :biggrin:
2 questions Tim,
Ok, that was slight fabrication of the truth.
But this is fact -
The British Army are currently carrying out a plausibility study into wether or not the Big Shot can be used to fire grenades over long distances.
So far the tests have revealed the furthest a grenade shot from a Big Shot was a distance of 16500 miles before exploded in mid air 15 miles outside the Earth's atmosphere.
