  • Replies 37
must say jcb's used to be all the rage round here in late 90's early 2000's.... not many about now... my cousin has one and has to have new one every yr as it becomes way to unreliable after that... mind you he's prob doing nearly 2000hrs a yr with it..
favourite tele has got to be Cat,use a lot of them in summer on staging work,all have huge hours but loads more reliable and nippy than the JCB s.dont think they available as Agri spec though?
Hi lads, Going of track a bit FENDT. Had brake cylinders off to repair found ball bearing in bottom do,s not belong there any idears, I think it should go in balance pipe????
cats are available with every type of agri spec you can think of... our local valtra dealer sells them... or not many as is case.... way over priced..
