Just come in Jon , Hilux says it's 7 degrees . Out of order for this time of year if you ask me !!
Hi trees they say it going to hit over 30c🌞🌞🌞🌞 this week thanks Jon
Hi NFG do you work in that heat mate thanks Jon
Yes, sometimes, block laying today then some garden work in about 35 & was welding the other day, sun so bright it triggered my mask, I recommend:
1. Drinking plenty of water doesn't have to be anything special, tap or Peckham Spring will do
2. Wear a hat with a brim, a shirt with a collar (as opposed to T shirt or vest) to protect your neck & UV sunglasses. I only use sun screen if Im going to be out for a while because it stops the natural build up of Vitamin D - However if you are susceptible then its obviously necessary.
3. Work steadily, dont rush - its easy to over heat
4. Take frequent short breaks if its really hot
5. Look out for others: skin on necks & legs ie areas where they can't see.
N
Edited by NFG
