I thaught I had pleanty of wood but it's going faster than I can split it.
L200 crewcab load - £50
1.9m3 Trailer £90
All seasoned but totally random mix. No willow or pops.
I still have people phone me and want it cheaper but the price is fixed.
Tree work has dropped right off tho so I hope the logs last long enough
  • Replies 158
Anyone that burns wood on a regular basis should have their chimney lined. No matter how long wood is seasoned for it still leaves resin in the chimney. The resin soaks into the brickwork and if a fire occurs it cant be put out, resulting in structural damage to the house. My chimney is lined with stainless steel and I still clean every two months or so depending on the type of wood I,m burning. Sometimes the first section of my six inch flue is chogged right up leaving a three inch hole. I know when it,s time to clean just by judging the fires performance. Also I season all my wood for two years whether it,s for me or customers.
All good stuff but in our experience well over the top - we have been running a full central heating system (3 bed detached with 7 full radiators) for the last 20 years on nothing but firewood. The chimney is unlined rough stone and is swept on an annual basis. We have had a couple of fres over the years when the wife forgets to get it swept and have no bother putting them out by shutting the chimney damper in.
We typically fell a load of wood in the winter - or block windblow - and in the spring split it and stack it under a tin roof - it is then burned from september onwards. We take little account of species but tend to burn softwoods in summer and hardwoods in winter.
Cheers
mac
Cheers
mac
I know its a bit over the top but I,m one of lifes worriers. I,m the same in what ever I do.
£258 for a full tipper, (6 cubes)
My calculations say that you're getting £43 per cube. We are currently getting £50 per cube - for softwood.
But, actually, do you really think you have 6 cubes on your Transit, it looks a lot less?
theres def 6 cube on the tipper lads...
transit carrys 2.5 tonnes. and if you where to fill a dumpy bag with wood..
each dumpy bag will only hold 300kg max 6x300kg=1800kg..
try it you will be supprised....:001_tt2:
I,ve always thought a transit could carry one and three quarter ton?
