Pretty much should just bolt on straight off the bat. The ABR stiff tethers or the sterling equivalent look great, but I just spliced up my own.
Will these stiff tethers floating about fit the zk1 rope wrench?
The ABR stiff tethers with the rubber piece directly in the eye are made specifically for the ZK-2 version of the Rope Wrench. The Rubber piece eliminates the possibility of the RW ZK-2 going into the neutral position.
If you are using this stiff tether on the ZK-1 you may want to cut the rubber piece off as it has a tendency to slip in between the sideplates and get stuck. Another option would be to significantly beef up the rubber piece with electrical tape or some other method to make it bulky enough to perform the task that it was designed for on the ZK-2..
Haha mate, what did I tell you all those months ago?!:sneaky2:
I know mate but for some reason I just never got on with the zk1 :confused1:
I'm still racking my brains to think why I would go back to Drt :biggrin:
Think I might be a while on that one
adam is it honestly THAT much better? i really want one but keep putting it off because of the whole switch over thing, and the fact i havnt worked with a hitch in 4 years because iv been on spiderjack, everytime iv had to use a hitchclimber iv hated it
