Has any1 used Morris lubricants bar oil?
i have been looking around at some bio oils and fount that Morris Lubricants do Terralus CBO, i was wondering if any of you guys have used it and if you think its any good or not.
i would like to know your finding wether bad or good.
Chain oil has the same spec as gear oil
Don't think so mate.Dip your finger into Bar Oil,press your Thumb against it and slowly remove your Thumb.There will be some "tack" like snot from your Thumb to your finger.
Gear Oil won't do that.
Chain oil is simlar spec to some machine oils but not gear oil. Completely different tolerances to heat and pressure,and environmental implications if your really fussy. At the end of the day though,better to use any oil than none at all.
