Abolition of the small trailer exemption Dec 4th 2011
  • Replies 155
as far as i can make out........if u pull a trailer weighing under 1000kg unladen...... this unladen weight does not count towards gross laden weight of vehicle and chipper.....so as long as the laden weight is under 3.5tonnes u dont have to has an operators license?
Yes asis my understanding. You'd need a light 4x4 to pull one of them and be under 3.5 ton.
so transit tipper pulling an 1100kg tracked chipper on a trailer will be ok
Edited by slasherscot
but your going to be using 2, trucks ,double the cost ?? arnt you :confused1:
I do already, how i set up, ones a tools and log wagon, the other chip and chipper tow, now ill just jiggle it about.
Driving Standards Agency has held a mini-consultation and the new regulations
will be in force prior to December.
Paragraph 3 of Schedule 1 of the Goods Vehicle (Licensing of Operators) Act
1995 exempts from operator licensing a ‘small goods vehicle’ forming part of a
vehicle combination (not being an articulated combination) where all the
vehicles comprising the combination excluding any ‘small trailer’ have a plated
weight not exceeding 3.5 tonnes.
A small trailer is defined under the Act as a trailer with an unladen weight not
exceeding 1020kg. This trailer does not need to be included when calculating
the 3.5 tonne limit.
However, under the Regulation all the vehicle combination (including any trailer)
operating for hire or reward must be included when calculating the weight limit,
so the small trailer exemption will be abolished for hire or reward operations
from 4 December 2011. However, the small trailer exemption under paragraph
3 of schedule 1 of the Goods Vehicle (Licensing of Operators) Act 1995 will
remain in place for operators carrying goods other than for hire or reward.
results from vosa public consultation..... 1st two sentances are worrying!!!!!
dot results... sorry!!!!!
Edited by robbo 110
confused
