Any stove experts out there !!
Tnarg25
Right, here's the problem. We were looking to put in a woodburning stove and the room its going in is approx 5m x 4m with a door leading off into a large kitchen/diner. Want a contemporary looking stove that gives out enough heat to heat both rooms. The two we like are Esse (5kw) and Firebelly (12kw) but cant see anything in between. Any advice on what would be our best option???
  • Replies 20
i think the 12kw may be a bit too hot in the room
i have an 8kw in about the same size room also with a door to a kitchen diner most of the heat stays in the room even with the door wide open
A 5kw may be ok for that room, depending on ceiling height and insulation.
I had a hunter hawk in a similar sized room. It was a little underpowered in multi fuel mode, but I removed the grate to increase the size of the firebox, which if you are only going to burn wood is better, and it was fine.
Were now on our 3rd stove - just installed a Stratford Eco boiler 20kw to run the ch and hw. Our previous Franco belge was fantastic too.
Check out the morso models. Expensive, but very nice.
I hope you've got a decent stack of wood seasoned :thumbup1:
