Has anyone else had any punctures on their Arb trolley?
Β
I've had 3 in two days!! And each time it's only a small bit of bramble or something similar.
Β
The garage I got the new inner tubes from said they might be able to get me a more heavy duty tyre, has anyone else upgraded theirs?
Β
Cheers
Β
Jonny:001_smile:
Still want one.
Β
Have you noticed that all the 'it's overpriced, I'll build my own' brigade have not exactly come up with a lot yet?
Β
I'm waiting for a lucrative big drag job to justify one, but expect they get used a fair bit once you own one?
Still want one.
Β
Β
Β
Β
i was part of that its to expensive for me to buy, so i bought cheaper model for Β£199 cant complain with quality either and makes life so much easier :thumbup1:
Still want one.
Β
Β
Β
Surprise, surprise!:laugh1:
Β
Β
Β
Cheers
Β
Jonny:001_smile:
Β
Jonny try this product
Linseal OKO Puncture Seal 500ml about Β£9 per litre
Still want one.
Β
Β
Β
Im was one of the "Its over priced, I'll build My own" Brigade but I did My sums and worked out I was easier to buy one and crack on.
Β
I have'nt had any problems and In the short time I've had it its been spot on and used on nearly every job.
Β
I would nt be with out it :thumbup:
Had a puncture within five minutes of using the trolley for the first time but when you run small pneumatic tyres on rough ground with a load on it's going to happen.
I got it repaired in minutes for a small sum and haven't had any bother since. No regrets!
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
