10 minutes ago, spudulike said:
5 thou is very good, 7 -15 thou typical, 20 is getting knackered. Obviously a single ring is more prone to compression loss than a double.
Ring end gaps, yes ?
I was attempting to put a number against the subjective piston to bore clearance.....obviously not very clearly. Cor blimey, just imagine 12000rpm, a piston clanking around with 20 thou clearance....
Well with the ring pushed square down the bore an inch I can fit the feeler gauge which says 100 on it through the smallest part of the gap and that's the biggest one I have. Think that means 1mm gap as its .05mm to 1mm guage so reckon that means worn right?
That's 40 thou; way too big a gap by a factor of 5, lots of gas escaping.
My experience is measuring at the base of the bore and never seen 40 thou on any machine. That is massively worn!!! 7-15 is fairly typical with 20 on a well used old machine being normal!
The cheapest fix would be to get a decent quality piston...OEM, Meteor, Hyway, Episan and fit that making sure it is set to rev as a 350 would be. Check the plating is still good on the bore and lightly hone to accept the new piston.
Nikasil looks ok on the pot. Any good places for rings? Only seem to be cheapos from China on Ebay or cabers from the states
