What do you guys do to seal the exhaust port on a 200t to do a pressure/ vac test?
Im sure there is easier ways than how I struggle?
Matt
Soft rubber sheet with two holes in it to accept the bolts - similar to you but better!
Had an stihl 024 from an engeineer i work along side every now and then. Was bogging striped down cleaned the carb dont think the saws seen much work. Had a load of junk in the carb ifllter think just from stale fuel . Any way was going to tach it. Any body know the max rpm ?
13,000rpm on that one - that is maximum so aim for circa 12500 on the chosen bar length - the L screw is left a bit lean as the carb can blow fuel back on to the filter if too rich.
Im still standing by the manifold being perished :lol: It does involve removing the carb and dropping the tank/handle to check which is a 10 minute job maybe 20 if your winging it a bit.
Bar and chain off
Remove air filter with a flat bladed screwdriver/scrench
Small flathead to remove black part of handle to remove carb linkage rod
Remove fuel pipe
10mm socket x 2 nuts to remove the carb-pull out circular insert and ring from end of manifold
Remove the triangle rubber buffer mount by carb t27 screws x3
Under Clutch drum lever out the 2 white round plugs (front 1 should have the silly chain guard thing on in case of chain breaking)
Then remove the 2 x t27 screws that live under them holding the tank in place.
Slacken/remove front end handle bolt/s
Should now be able to feed/push the inlet manifold thru the plastic handle along with impulse and remove handle to inspect the manifold properly aswell as the impulse. (impulse can be a pig to fit with handle in place unless you have forceps or similar)
I am skilled at this now as I did each component on their own. I did remove the manifold but could not find any deterioration. I flexed it, examined closely. I could as you say fit one to try. But I don't fancy doing that, then doing the carb with a kit. Then it is something completely different and a write off. Lack of confidence and experience and without you helpful folk it would be without knowledge. I have rebuilt tractor transmissions that have failed and done heavier mechanical repairs. But small engines are an unchartered territory when it gets more complex for me.:001_huh:
:thumbup1:
Here we go, a bit of saw porn for Eddie:001_rolleyes:
I did tach the saw today - then found the recoil had jammed and a quick inspection showed the flywheel had come loose and was rubbing on the starter pulley:001_rolleyes::lol: I held off the auto vane rev limiter - boy that sounds flash for a flappy thing that closes the choke if it goes a bit fast:lol:
Anyway - held it off and adjusted the carb for 7500rpm and then set the autovane to kick in around the same - don't think I am too far off the mark in doing this.......am I Eddie????? First one I have done....ever!
Last pic is a comparison to the 3120XP - now singing again:thumbup:
Pics: -
Looks a bit heavy :001_rolleyes:
They both are - especially when you forget to connect the fuel line to the 3120XP and drop start it 20 times:001_rolleyes::lol: burke:lol:
Abbey say your seal will be with me today:001_rolleyes: hope it will hit tomorrow:lol:
Thanks Verry much spud . That stihl is it similer to 070 have one i am meaning to do up have a few spots on tbe caseing to braze up. And that 3120xp dose it even know its in wood with that bar on it ? :thumbup:
No idea - just put it on there to run it up - I dont think it would stop it even if you put full weight on it:lol:
20" before anyone asks!
