Are episan pistons ok?
was looking for an oem, found one with no rings so hoping i can still get rings from a dealer for a 051.
any help great. cheers
Episan will be fine.
Still available but not cheap oe (about £11 each iirc)
P/n
1115 034 3010
Same rings as on the ms380 and 381 :sneaky2:
P/n
1115 034 3010
is it worth holding out for the stihl? or just get the episan?
stihl would be 44 quid episan 26 quid
episan from greece like meteor :)
Episan are Turkish and are manufactured well, Meteor are Italian and take some beating. Unless you can get OEM for around £50, I would always use Meteor and then Episan as a good replacement.
ms180, not oiling, cleaned out and reset the pump in its place with the holes. all good. also looked like the chain had been sharpened with a flat file. so thats sorted.
hs45, running problem, tweak on the meter arm. all good.
husky 435, new oil pump fitted, now runs good, and a quick sharpen.
todays drop offs. ms660, chain brake issues. so checking all the parts out before going for the exhaust.
ms260, blown piston.
now waiting for the arrival of a rotorvator, needing new tynes, complete engine service, and a good clean up, with painting and removing any rust.
Nice amount of work there Rich!
It is.
Also got a chipper coming in at some point with brake issues. And a general service.
A few mowers coming in from domestic people aswell.
Oh and finding time to get my truck over the pit before it's MOT is due.:001_rolleyes:
well, im gutted, you could only see a little through the ports and only looked to be a few lines on the piston, was hoping for a quick clean and new piston.
Ordered new piston oem stihl on ebay.... stripped down and gutted, cant clean/filler this lol
So the saw is the old 051av.
Few options :
1) wait and hunt around for a 2nd hand good cylinder to come up and fit my piston to
2) buy an aftermarket 051 p&c
3) buy an aftermarket 076 p&c ( not sure what else, hear inlet manifold and exhaust....)
Bugger :sneaky2:
Wonder how much an oem cylinder is?
I had a cheap set and the dies cut a rounded poor formed thread and the taps weren't much better!
If you can wait, keep a look on ebay for an old set of decent brand ones when the Japanese manufacrtured some decent kit or old British ones - you can get some good sets coming up.
Worth also having a set of helicoils in M5 and M4/M6 also.
i wouldnt use helicoils your better off with timeserts bit dearer but worth every penny :thumbup:
Few options :
Bugger :sneaky2:
l and s engineers do them i think same as some large disc cutters,
