Todays job was to make at least 2 Fs310 strimmers out of 6 in various states of repair, then realised ive run out of Dirko. So im having a day of doing nothing.
:lol::lol::lol::lol::lol:
u and ur cake :lol:
Martin, just wait a bit and you too will be an expert on the Octonauts (and making associated blue cakes).:biggrin:
Alec
Alec
My twin five year olds (and their mum..) made me a cake with bright green icing and trees on the top... Meatball trees!
(On top of spaghetti, all covered in cheese....)
Ok. I keep looking. It's for a trust so I'm not ordering anything until they say so.
I've been looking Ito pressure testers. I have a vac tester coming but what pressure testers is everyone using?
I use this, combined pressure and vac pump.
A very versatile tool, not only for crankcase testing, buy was recently invaluable when I had to bleed the diesel through on my transit.:thumbup1:P1010006.jpg.2866c56b9197bf0142b7e8b452c5d9c6.jpg
Sometimes the oiler worm drive arm rotates around the plastic gear it sits on - it should be a semi tight fit and only slip if the worm drive locks up - fitting a new one is relatively easy if it is this:thumbup:
OK at risk of sounding daft hoe do you get the oil pump out (ms180 i can see it but not sure how to get it out)!:confused:
Cheers
Mark
Sent from my GT-S5690 using Tapatalk 2
First got back a page and loo at gardenkits post over it.
Second if you mean the worm gear then its anti clockwise turn while gently pulling on it after clutch removal.
And it's the first one alvin.
Edited by Rich2484
Cheers
Mark
If you can see it, screw an m5 bolt into it and just pull up on the bolt.
