diesle van heaters need some info ??
Littletree
Hi all I am looking into having a diesle van heater fitted into my van via the tank as live most of the year in it and winter is fast approaching .
If anyone has had one fitted to there camper van can let me have the details of where you had it done ?
Thanks Littletree:thumbup:
For the tiny amount they use fitting a tank would be disproportionately expensive
No it wouldn't, all it would need is a standard yerrycan, makes filling it a doddle too. If he lives in it "most of the year" as he says he'll go through quite a bit of diesel. The other (priceless) advantage is that if you're low on fuel, you may get chilly but you will still be able to drive to the pump!:sneaky2:
